Thread: JBL BPX amps....anygood??? |
| Posted on Monday, September 13, 2004 - 05:59 pm: |
i am looking at the JBL BPX amps, but i dont know if they're any good. anyone know if they are??? i am mainly looking at the BPX1100.1's....any good? |
| Posted on Monday, September 13, 2004 - 07:05 pm: |
Not as good as others for the money. But JBL makes good amps. The BP series was better |
Unregistered guest |
| Posted on Monday, September 13, 2004 - 09:47 pm: |
is the jbl 1200.1 gto good enough to push 2 12 inch kicker L 5's |
| Posted on Tuesday, September 14, 2004 - 11:56 am: |
It puts out 1114w at 2ohms....what confuration are your L5s? |
| Posted on Tuesday, September 14, 2004 - 06:29 pm: |
what does confuration mean |
Bronze Member Username: A3forme
Post Number: 64 Registered: Sep-04
| Posted on Tuesday, September 14, 2004 - 08:21 pm: |
Are they Dual 4ohm or Dual 2ohm L5s? |
| Posted on Tuesday, September 14, 2004 - 10:20 pm: |
it says dual dual 2 ohm = 4ohm load and dual 4 ohm = 8 ohm load and u can check to see here http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26item%3D7916448874 |
Post Number: 72 Registered: Sep-04
| Posted on Tuesday, September 14, 2004 - 10:46 pm: |
Have you bought these yet? The dual 2ohms will work with the JBL GTO1201.1 see the middle diagram in the link below. http://www.crutchfieldadvisor.com/S-Szr6cWT7FJK/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC2x2 BTW, if you haven't bought them, seriously consider a round sub first. That's my $.02
| Posted on Wednesday, September 15, 2004 - 04:27 pm: |
i have already baught the kicker 12 inc L 5's because i got my 2 subs and a box for 215 so i got a good deal.....and i heard they were good so which jbl should i get it says dual dual 2 ohm = 4ohm load and dual 4 ohm = 8 ohm load and u can check to see here http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26item%3D7916448874 |
