Thread: What to look for? |
New member Username: Vero
Seguin,
TX
U.S.
Post Number: 1 Registered: Sep-04
| Posted on Monday, September 13, 2004 - 03:10 pm: |
I just have a question. If I was interested in buying an amp for a system that I'm getting what do I need to look for in an amp? I'm getting 2 12' inch POLK Audio Subwoofers and I really don't know what kind of amp I should get. Any suggestions? |
Gold Member Username: Jonathan_f
GA
Post Number: 1604 Registered: May-04
| Posted on Tuesday, September 14, 2004 - 12:46 am: |
Which Polk subs are you planning to run, and what impedance are they (4 ohm, dual 4 ohm, etc.)? For best bang for the buck, a mono subwoofer amp will do you well. I'll recommend one once I find out which subs you're planning to get. A 2 channel will offer more sound quality, but with increased current draw from your vehicle and a more expensive amplifier. |
