Thread: Help With My System, I know Nothing |
New member Username: Bigap15
Post Number: 3 Registered: Sep-04
| Posted on Sunday, September 12, 2004 - 10:18 pm: |
What I would like to know is profile amps any good, i can get a really good deal on a 1200 watt amp with 300 X 2 rms power, Just what i need, Also should i get a High output alternator or a cap. I can get one around the same price so which should i get, If i do get a new alternator should i get a new battery. |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 565 Registered: Apr-04
| Posted on Sunday, September 12, 2004 - 11:02 pm: |
I have a profile 400W just pushing a 10" RF sub and it is alright for that one sub. I would say that Profile amps a horribly underpowered. There kinda like sony amps. |
Silver Member Username: Caraudiofng
Houston,
TX
Post Number: 271 Registered: Aug-04
| Posted on Sunday, September 12, 2004 - 11:53 pm: |
Profile is unreliable and as Pat said....HORRIBLY underated. You want something inexpensive and workable....Look at Hifonics or JBL. |
Bronze Member Username: Allpro
Dacula,
Ga
United States
Post Number: 12 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 05:16 pm: |
What kind of budget are you on...and what sub/s will you be running? |
