Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Help me pick an amp plz
Author Thread: Help me pick an amp plz
Username: Nysteelers
Post Number: 44
what would be a good amp for 2 12' kicker solobaric L5's? it is going in my SUV. would the jbl 600.1 be good u think?
Johnathan
yes if subs are 2 ohm wired in parralell
Post Number: 45
ok thanks...what if they are 4 ohm though? what would you recommend i get, and im tryiung 2 keep this as inexpensive as possible
Johnathan
jbl 1200.1
Post Number: 46
thanks
Johnathan
no worries dude
Username: Allpro
Dacula, Ga
United States
Post Number: 14
JBL 1200.1 inexpensive?????? Mike, what is your budget and will your subs be sealed or ported?
Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Help me pick an amp plz [ « Previous ] [ Next » ]
