Thread: Whats wrong with this? |
New member Username: Ginuwinepz
Post Number: 8 Registered: Aug-04
| Posted on Sunday, September 12, 2004 - 11:55 am: |
I have a 1000 watt sony amp running a 15" kick comp VR, and a 500 watt sony amp running my full ranger speakers in my car, it sounds awesome, cept when i have it cranked up, my full range speakers cut out for just a second, the amp stays on and everything, but the speakers cut out, sometimes they dont do it though...i have no idea what the problem is, any help would be greatly appreciated! |
Bronze Member Username: Audiobahn_man
Freakmont,
MI
Post Number: 38 Registered: Aug-04
| Posted on Sunday, September 12, 2004 - 12:27 pm: |
set your gain lower on the 500 amp, your putting way to much poer to the component speakers |
Post Number: 9 Registered: Aug-04
| Posted on Sunday, September 12, 2004 - 02:12 pm: |
Thanks, that worked! |
Johnathan Unregistered guest |
| Posted on Sunday, September 12, 2004 - 07:42 pm: |
no problem |
Post Number: 10 Registered: Aug-04
| Posted on Monday, September 13, 2004 - 12:30 am: |
I have my gains turned down on my amp....and it worked ok for a little bit, and now it is back doing the samething, only a little bit worse now, my full range speakers for full range speakers i have 2 kicker 4x6's and 2 explod 6x9s it only cuts out when the bass hits hard. any other ideas? |
| Posted on Monday, September 13, 2004 - 01:36 am: |
your charging system my not have the power it needs to keep up w/ your amps. you make need a bigger alt. |
Bronze Member Username: Ginuwinepz
Post Number: 11 Registered: Aug-04
| Posted on Monday, September 13, 2004 - 08:33 am: |
I have a brand new alternator, it is not any higher amperage or anything, but i also have a 1.0 farad power cap. and it was not doing it earlier....could it be something with my RCAs or Remote? because i noticed that i can hear a high pitched noise out of my speakers now when i accelerate if the volume is turned down. |
Bronze Member Username: Fishy
Post Number: 14 Registered: Sep-04
| Posted on Monday, September 13, 2004 - 09:48 am: |
Check your grounds. Make sure your amps are grounded as close as possible to your cap(w/o makin huge runs of course). Also check your RCA connections. I installed an electronic crossover in the compartment under my armrest in my Explorer(so I could tweak while in motion ). It was a tight fit and one set of RCA's was pressed against my center pillar and forced up a lil bit. This caused some engine noise. Once I gave them some room and relieved the pressure on my Xover outs I lost my engine noise. -Fishy |
Post Number: 12 Registered: Aug-04
| Posted on Monday, September 13, 2004 - 11:18 am: |
thanks, i will try that, and let you know |
Silver Member Username: Koz1031
Monticello,
In
United states
Post Number: 111 Registered: Jul-04
| Posted on Tuesday, September 14, 2004 - 06:38 am: |
also make sure your rca wires run down the oppisite side as the power wires. |
Monticello,
In
United states
Post Number: 113 Registered: Jul-04
| Posted on Tuesday, September 14, 2004 - 06:39 am: |
also make sure your rca's run down the oppisite side as your power wire. |
Post Number: 13 Registered: Aug-04
| Posted on Thursday, September 16, 2004 - 12:44 am: |
Thanks guys, i got it sounding AWESOME now...i have my one 15" sounding louder and better than a guy with two of the exact same subs! it sounds GREAT! |
