Thread: Amp for 2 infinity kappa perfects 12.1 |
Bronze Member Username: Crappycarguy
Post Number: 14 Registered: Sep-04
| Posted on Saturday, September 11, 2004 - 02:48 pm: |
I need an amp to power them perfectly anyone know of a good solid amp to do this the perfects are 350 watts rms each and I can either get them dual 4 0hm or just regular 4 0hm so whatever is easier. thanks |
Bronze Member Username: Sixstar
Post Number: 53 Registered: Aug-04
| Posted on Saturday, September 11, 2004 - 10:30 pm: |
How much $$ you got to spend on an amp? If you don't have too much money, go with the dual 4ohm subs, and wire it so you get a 1 ohm load to your amp. ex. amp, Hifonics NX750D A little more money, and go with the single voice coils, and wire them to give the amp a 2 ohm load. ex. amp, MTX Thunder801D (800w, a bit too much). |
Post Number: 16 Registered: Sep-04
| Posted on Saturday, September 11, 2004 - 11:55 pm: |
would the hifonics brutus bx1000d power them perfectly? |
New member Username: Outlaaw
Post Number: 4 Registered: Sep-04
| Posted on Saturday, September 11, 2004 - 11:56 pm: |
i got the same subs but i was gonna get the brutus 1000D would that work too for those subs??!?!?! |
Gold Member Username: Jonathan_f
GA
Post Number: 1574 Registered: May-04
| Posted on Sunday, September 12, 2004 - 01:39 am: |
JBL 600.1 would be good. Amps are underrated, so they'll give those subs the 350W RMS they'll need. |
Post Number: 17 Registered: Sep-04
| Posted on Sunday, September 12, 2004 - 01:21 pm: |
that amp is discontinued isnt it? |
Johnathan Unregistered guest |
| Posted on Sunday, September 12, 2004 - 07:44 pm: |
no, you can still get it |
