Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > About Low/High level outputs
Author Thread: About Low/High level outputs
Username: Metall1cfan
My amp is wired for low level output, but do I need to go ahead and install it for high level output too? I plan on only using the low level though...
I read somewhere that this could cause damage by running both...
I have everything installed and it works...just not like it should...barely anything comes out of the subs...I'm thinking its the frequency..or bad wires..
Username: Pat_l
Tucson, AZ
Post Number: 554
You need to turn you gain up. If you use the amp foe hi-level then your using it for component speakers, if you run low-pass then your using it for subs. If nothing is barley coming out then it could be 2 things: Gain not set right (turn it up) or too weak of an amp to power the subs.
amp is 1000watts..so it must be the gain?
Johnathan
yes, the gain, turn it down
Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > About Low/High level outputs [ « Previous ] [ Next » ]
