Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > Will this amp work??
Author Thread: Will this amp work??
Username: Outlaaw
hey i dont know much about this stuff but i was planning on buying HiFonics Brutus BX1500D and hookin it up to 2 Infinity Kappa Perfect 12.1 subs but i dont kno if that amp will work with those subs any suggestions? plz help
Username: Outlaaw
here are the specs on that amp
Amplifier Type: Mono
RMS Power: 450W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: 0.08%
RMS Power: 900W x 1 @ 2 ohms
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-250 Hz
Signal to Noise Ratio: 90 dB
Fuse Rating: 2 x 60 amps
and specs on subs
Rec. Sealed Box Dims: 1.00 cu.ft.
Rec. Ported Box Dims: 1.75 cu.ft.
Free Air Usage: not recommended
Sensitivity: 96 dB
Frequency Response: 18-150 Hz
Recommended RMS Power: 350W
Peak Power Handling: 1400W
Impedance: 4 ohms subwoofer wiring options
Username: Davids2004
Houston, TX
Post Number: 748
Its gonna give you a little more power then needed but you will be fine. Those specs on the amp are listed at 14.4 volt so it wont be as high as the 900 watts at 2 ohms.
Username: Outlaaw
hmm can i go with HiFonics Brutus BX1000D and save me some money and get enuff power??????(remember i dont kno anything bout this kinda stuff)
Johnathan
jbl
Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > Will this amp work?? [ « Previous ] [ Next » ]
