Thread: Need help please. |
New member Username: Tekd
Post Number: 1 Registered: Sep-04
| Posted on Friday, September 10, 2004 - 07:08 pm: |
I have a Boss Audio AVA-650 4 channel 150x4 etc. Its been working for awhile but now the protection light wont go off at all i have tried everything i took the circuit board out and looked at everything nothing is blown. all caps look fine. I have two amps I even tried it on my other connections so i know its not a bad ground, nothing has worked for me so far :[ well my question is, is there anyway to bypass the protection mode ? please help me. |
Silver Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 112 Registered: Aug-04
| Posted on Friday, September 10, 2004 - 07:44 pm: |
yes, get rid of the boss amp, in my opinion they are bad and probably most people on this forum will say that they are bad. I would recomend getting a new amp, not sure what to buy, havent had any four channel amps. My brother had a kicker 4 channel and it pushed some boston acoustics really good, it sounded real clean. But thats just my opinion. |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 544 Registered: Apr-04
| Posted on Friday, September 10, 2004 - 08:33 pm: |
Well if you have 2 amps and you said that you tried the other one on the same connections and i worked then its something wrong with the one amp. I would try to get it fixed- its not worth it. Buy something better. |
Bronze Member Username: Koz1031
Monticello,
In
United states
Post Number: 98 Registered: Jul-04
| Posted on Saturday, September 11, 2004 - 05:56 am: |
If it's still under warranty, take it back and get another one. |
