Thread: TEAM TREMORS |
New member Username: Teamtremors
Post Number: 1 Registered: Sep-04
| Posted on Friday, September 10, 2004 - 01:15 am: |
watsup i'm a founder member of my upcoming team tremors.i'm only 18 i am using 4 12s pioneer premier ts-w2000spl subs runnin off 2 alphasonik pma-1000da. would that get loud,while sounding deep and have good response to low freqs like 30hz. also if those subs arent good tell me what are they're downfalls and if they are tell me they're pros. also i was thinkin of 4 12inch rf punch hx2 2212. help me out |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 542 Registered: Apr-04
| Posted on Friday, September 10, 2004 - 05:54 pm: |
I am not a fan of pioneers. I would consider upgrading, especally if you want to take you team to compititions. Most of us on this forum are in the range of 16,17 and 18. |
Bronze Member Username: Allpro
Dacula,
Ga
United States
Post Number: 20 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 09:51 pm: |
Go with the Rockfords!!!! But not go with the Hx series...They are last years subs and this years Stage 3 subs rock. You will have som much sound it will numb your mind...trust me |
New member Username: Thedirk
Potsdam,
NY
Post Number: 3 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 10:00 pm: |
ya go kickers or ive even had alot of luck with MTX if ya dont wana spend alot..i never had any luck with like jensen or pioneer rockfords, are good... eve even had incredable luck with a planet audio 10"Er.....im 20 :P |
| Posted on Wednesday, September 15, 2004 - 10:24 pm: |
adire, RE, DD, Oz, Arc, JL...all of these are great! |
