Thread: What amp should i buy |
New member Username: Vegeta11
Baton Rouge,
LA
U.S.A
Post Number: 2 Registered: Sep-04
| Posted on Thursday, September 09, 2004 - 10:38 pm: |
i have 2 jl 12w3v2 and 1 jl 12w3 all three are 4 ohms someone told me jl's sound better in odd numbers will i just be wasting my getting all three hooked up if its worth it will it sound ok if so what type of amp should i get |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 750 Registered: Jun-04
| Posted on Saturday, September 11, 2004 - 10:52 am: |
I would hook up the two w3v2. I belive the rms wattage is 300 rms on each of those subs. If you can get a 2 ohm load out of those subs look at the xtant A6001. If you can get a 2 or 1 ohm load look at the jbl 600.1. |
Johnathan Unregistered guest |
| Posted on Sunday, September 12, 2004 - 08:15 pm: |
sony 1600w p5 |
Bronze Member Username: Allpro
Dacula,
Ga
United States
Post Number: 13 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 05:19 pm: |
Rockford is back old school...Awesome new POWER series and ARC has some incredible sounding amps on the circuit. What kind of budget are you on? And three JL's absolutely rock! |
