Thread: External crossover. |
Silver Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 107 Registered: Aug-04
| Posted on Thursday, September 09, 2004 - 09:17 pm: |
hey yall, my brother gave me his old crossover, its old. It is an Audio Control 2xS It says on it Electronic 18 dB/octave programmable crossover-line amp-subsonic filter and bridging adaptor. all it has on it are 1 set of inputs, low frequency output, high freq. output, and (im confused) a mono&bridging RCA output. is it good? and what does it mean by mono and bridging on the RCA OP it also says by the mono and bridge RCA invert on one RCA out and normal on the other? Answers please or input on this. |
LaPlace,
Louisiana
United States
Post Number: 108 Registered: Aug-04
| Posted on Thursday, September 09, 2004 - 09:42 pm: |
hey |
LaPlace,
Louisiana
United States
Post Number: 110 Registered: Aug-04
| Posted on Thursday, September 09, 2004 - 11:00 pm: |
c'mon, please tell me, someone has to know. |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 533 Registered: Apr-04
| Posted on Thursday, September 09, 2004 - 11:02 pm: |
Audio control crossovers are very nice. I would probably kept it. One of the better lines |
New member Username: Fishy
Post Number: 9 Registered: Sep-04
| Posted on Friday, September 10, 2004 - 01:46 am: |
The 2XS has been around forever. I owned one and if I remember corectly there's a set of stereo outs for the lows and one mono and one inverted mono. Back in the day some amps(Soundtream for example) only used one rca input when bridged mono. The mono output(s) were used to run these type of amps. In some sytems the bass gets out of phase with the mids and highs a bit and the inverted mono output sometimes made things sound better. Also, the early(and I mean early)PPI amps required a bridging module on the inputs and i believe(not sure) this setup allowed you to get away without one. Most, if not all, of today's amps use both inputs for mono operation so you can just use the stereo outs and your amp will do the channel summing for you. If you want to use the mono out(try out the 180 degree phase shift) just use a Y connector either at the amp or the Xover. I sure did like my 2XS. I made a bunch of frequency chips(still got em) out of some resistors and IC sockets. If the thing is still around 20 years after the fact its gotta be good, no? -Fishy |
LaPlace,
Louisiana
United States
Post Number: 111 Registered: Aug-04
| Posted on Friday, September 10, 2004 - 07:32 pm: |
thanks dudes, for your input. Ill definitely keep it, as a matter of fact, i just finished hooking it up in my truck today. |
