Thread: Auto shutoff? |
Bronze Member Username: Dean_k
Regina,
SK
Post Number: 25 Registered: Jun-04
| Posted on Thursday, September 09, 2004 - 06:53 pm: |
do most amps automatically shut off when the battery is running low, or will they just eat up the juice until the battery is too dead to crank over the engine? i always run my stereo without the engine on, and it can run for hours without dieing, but now im getting a much more powerful amp if the amps dont do this on their own, are there devices that can cut the power when it gets too low? thanks |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 530 Registered: Apr-04
| Posted on Thursday, September 09, 2004 - 06:59 pm: |
No, there are not any, some may have a device, not many at all. If i was you i would upgrade the battery, because running your system w/ out the car on will eat up the battery like mad. |
