Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > Looking for Amp!!!
Author Thread: Looking for Amp!!!
Username: Mjv817
Here are the specs on my subs but i dont have an amp and was wondering what amp i should get for those, i only want to spend around 400-500 bucks on an amp
Audiobahn Dual 12" 800W Bandpass Encl
Dual Angle 12" Tuned Bandpass System
High Quality MDF Construction
Black Suppleather Covering
3/8" Plexiglass Window
Blue Interior Neon Lighting
Mirrored Interior Panels
Dual 12" PHAT 2" Foam Surround, Non-Pressed KM3™ Coated Cone Subwoofers
50 oz. Strontium Magnet
2" 4-Layer ASV Voice Coil
Bumped Back Plate
Extended & Vented Pole Piece
Gold Binding Post Terminals
Power Handling: 800 Watts RMS
Sensitivity: 104dB
Frequency Response: 28Hz - 150Hz
Impedance: 4 Ohm Stereo
Dimensions: 15"(H) x 29.75"(W) x 16.75"(D)
fgjgdhgkgf
Cuspid AM4310 1600 watt amp.... Very nice... you can get for around 50-100 on ebay BRAND NEW..... i did
Visitor#78
Yeah, and you are a freakin retard fgjgdhgkgf.
To sound half way decent ( aside from being audiobahn), those subs will need 600W rms.
Try the JBL BP1200.1
Phoenix Gold XENON 1200.1 (1200w RMS 1-4ohm) $475 shipped
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5719547633&rd= 1
MTX 1501d $366 shipped (1500w 2 2ohms, 750 per sub)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5719548170&rd= 1
Good Luck!!!
Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > Looking for Amp!!! [ « Previous ] [ Next » ]
