Thread: Help please |
New member Username: Bender
Post Number: 1 Registered: Sep-04
| Posted on Wednesday, September 08, 2004 - 08:30 pm: |
waddup, i just picked up a single Rockford Fosgage Punch Stage 3 12" sub, max 1,000; RMS 500. I know absolutely nothing about this stuff, so are there any suggestions as to what type of amp to get and will i need to purchase a new cd player as well? |
Post Number: 2 Registered: Sep-04
| Posted on Wednesday, September 08, 2004 - 08:32 pm: |
I have replaced all of the door speakers as well, i'm not sure if it makes any difference. it's a jeep grand cherokee also. |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 742 Registered: Jun-04
| Posted on Thursday, September 09, 2004 - 10:17 am: |
I know its dvc. Is it 2-4 ohm sub and im guessing you only have 1. |
Bronze Member Username: Allpro
Dacula,
Ga
United States
Post Number: 19 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 09:45 pm: |
I have a Stage 3 12" DVC4. It is run by a T5002 which is rated at 500 watts but was tested at 840 watts. I also have another T5002 running a set of MB Quart components. Sounds incredible. i have installed several setups just like this and it will make the hair on your neck stand up. |
New member Username: Thedirk
Potsdam,
NY
| Posted on Wednesday, September 15, 2004 - 09:49 pm: |
your going to need at leaste a say 600W max amp... rms say 200 per channel, if ya bridge an amp like that to her it would sound ok, other wise ya gota go top end to power the sub correctly...go with allpro's setup sounds like a killer also if the sub is 2 olms, make sure tha amp is same with 4 thedirk |
Dacula,
Ga
United States
Post Number: 25 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 10:46 pm: |
Mathew, hit me up when your ready to purchase. I can get high-end equipment just over cost... |
Dacula,
Ga
United States
Post Number: 26 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 10:49 pm: |
Bronze Member Username: Fishy
Post Number: 38 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 10:56 pm: |
Can you get Zapco, JL Audio, or Xtant? I've got an ancient PPI pro mos 2050 running my subs I'm thinking about retiring. It used to barely get warm bridged into 2 ohms. Now its startin to get hot as hell. Bought a bunch of cooling fans but...... upgrading might be a better idea. She has a lot of miles now after 15 years.
-Fishy |
Post Number: 39 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 11:01 pm: |
lol, in fact I could even come pick the stuff up. My brother used to live in Dacula, in Alpharetta now and I'll be up that way in a month or so. -Fishy :P |
Dacula,
Ga
United States
Post Number: 29 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 11:17 pm: |
No problem Fishy... I do not have a shop though. I sold that several years ago but still can get the products. Just let me know what you want and I can get you the prices I can get it for. allproaudio2004@yahoo.com Take care... |
Gold Member Username: Jonathan_f
GA
Post Number: 1650 Registered: May-04
| Posted on Thursday, September 16, 2004 - 12:55 am: |
15 years is a fantastic run from an amp, I'm sure you feel you got your money's worth  |
