Thread: Quick question |
| Posted on Wednesday, September 08, 2004 - 04:59 pm: |
i have a 1300watt ma audio amp mono channel could i do btter |
New member Username: Stevencarr
Arlington,
TX
United States
Post Number: 4 Registered: Sep-04
| Posted on Wednesday, September 08, 2004 - 07:53 pm: |
The question doesn't make much sense if you don't say what you'd be using this amp for. |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 743 Registered: Jun-04
| Posted on Thursday, September 09, 2004 - 10:18 am: |
This is what I say. Hook it up and if you like the sound then thats all that matters. |
| Posted on Saturday, September 11, 2004 - 01:23 pm: |
im trying to push two 12 inch audiobahn subs and my bad its an 1200watt amp |
Visitor#78 Unregistered guest |
| Posted on Saturday, September 11, 2004 - 01:39 pm: |
You could do better by getting rid of both, and starting over. But at least get rid of the Audiobahn stuff.... |
Johnathan Unregistered guest |
| Posted on Sunday, September 12, 2004 - 08:11 pm: |
audioshite |
Bronze Member Username: Allpro
Dacula,
Ga
United States
Post Number: 15 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 05:24 pm: |
Which MA amp is it and which audiobahn subs? Some of the MA Amps are extremely powerful, depends on what your wanting to do. There are a lot of amps that are cleaner though. |
