Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > 98 Jeep Grand Cherokee help
Author Thread: 98 Jeep Grand Cherokee help
i was just wondering if anyone had info on a 98 JGC with an infinity gold system. Is it hard to wire for subs if i still used the factory deck, should i buy a new deck, etc.
Username: Anti_crombie
WA
Buy a new deck, way easier to wire than messing with the stock deck. Also its really hard to find a stock deck that will allow you to wire subs unless it comes stock with a sub.
Username: Kyle8705
what about the factory amp, can i keep that amp and somehow get that amp and the new amp for the subs hooked up to the new deck or is that impossible.
Username: Ctx
Post Number: 42
no the factory amp is for just your door speakers
Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > 98 Jeep Grand Cherokee help [ « Previous ] [ Next » ]
