Thread: Ohm Questions Designing New System |
| Posted on Tuesday, September 07, 2004 - 07:41 pm: |
This is as far as I could get from reading other posts. I want the best bang for the buck system I can get. Please help if I should change any of these options, and if you have ohm advice. So far: Nakamichi CD-400 $309 PPI PCX-250\RB $109 2 channel 100*2 @ 2ohm Focal 165K2 $379 100w PPI PCX-2125\RB $239 2 channel 500w steroe bridged @ ?4ohm? (stereo or mono?) (opt. PPI PCX-1250 $319 mono 500w bridged @ ?2ohm? ?require DVC subs?) Cerwin Vega V-MAX12SVC 180 800w @ 2ohm (opt. Adire Shivas 250) |
ThatGuyYouKnow Unregistered guest |
| Posted on Wednesday, September 08, 2004 - 01:33 am: |
Use this link http://www.rockfordfosgate.com/rftech/wiringwizard.asp Does it match up? even if its not subs ohms are still ohms P.S. srry im too lazy to do it for you  |
| Posted on Wednesday, September 08, 2004 - 01:04 pm: |
Correct me if I'm wrong.. The only difference between 2 svc or dvc subs is that the dvc can be configured for .5 ohm. Assuming my 2 subs are set up in paralel for 2 ohm I can use either the 2 channel in stereo set at low pas, or the mono bridged. Is there a benefit either way between 2 channel and mono besides the 2 chanel being $80 cheaper? Would one vmax with 500w be better than 2 with 250w each? Are the Shivas worth $70 more than the vmax? Could someone explain or send a link on stereo vs mono bridging? Would the Pioneer Premier DEH-P8MP have better spl and sql then the Nakamichi cd-400? Is there a top of the line amp from a cheaper company that is better than the bottom of the line PPI? |
Silver Member Username: Iamduff_87
Michigan
America!
Post Number: 241 Registered: May-04
| Posted on Wednesday, September 08, 2004 - 10:50 pm: |
you can find the V-Max SVC for 109 at acaraudio.com you can find the Shiva from the manufacturer for 125 i believe at adireaudio.com |
| Posted on Thursday, September 09, 2004 - 11:46 am: |
the price comparison, $180 vs $250 was for (2) 12" svc subs.. I was under the impression that the sound was comparable, but the shivas were a better quality. I just dont know if the quality difference is worth $70 more. |
