Thread: MTX Thunder8000 12" Subs |
New member Username: Kyle8705
Post Number: 1 Registered: Sep-04
| Posted on Tuesday, September 07, 2004 - 06:03 pm: |
I just bought 2 12" MTX Thunder 8000 subs and i was wondering what would be a good amp for them. They max at 800 watts each, RMS is 400 watts each, and they are 4 ohms. Any input would be appreciated. |
Bronze Member Username: A3forme
Post Number: 12 Registered: Sep-04
| Posted on Wednesday, September 08, 2004 - 11:55 am: |
If you go ported, the Kicker KX600.1 would be great because they are usually underated (put out about 700w RMS to give 350w per sub). You can find them for about $275 or a little less. MTX 801D would also be a good choice, about $260 shipped. The Phoenix Gold OCTANE R8.0:1 would give full power to your subs. $245 shipped. The Hifonics Brutus BX1000D would also work. $240 Shipped That's all on ebay.... |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 744 Registered: Jun-04
| Posted on Thursday, September 09, 2004 - 10:20 am: |
Also take a look at the xtant A6001 also. Its around the same prices as those amps above. |
