Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > Wondering if I'll have enough power.....
Author Thread: Wondering if I'll have enough power....
dirrrty2000
I'm about to put a HiFonics BX1500D on a set of 4 Pioneer TS-W255C 4 ohm subs wired down to 1 ohm. The subs are rated for 350W RMS and 700W Max. The amp supposedly puts out 1500W at 1 ohm... Just wondering if it would be enough I guess
Username: Davids2004
Houston, TX
Post Number: 725
Yea you will be giving each sub a little more then 350 rms a piece which is perfect for those subs. That 1500 rms is rated at 14.4 volts also so you will be fine.
Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > Wondering if I'll have enough power..... [ « Previous ] [ Next » ]
