Thread: MTX 801D v.s MTX6500D |
| Posted on Monday, September 06, 2004 - 02:33 am: |
Same but differernt name? 801d http://mtx.com/caraudio/products/amplifiers/thunder801D.cfm 6500D http://mtx.com/caraudio/archive/thunder6500d.cfm
Bronze Member Username: Squanto
No,
No
Usa
Post Number: 24 Registered: Aug-04
| Posted on Monday, September 06, 2004 - 12:18 pm: |
pretty much, except the 6500d gets 450w with a 4 ohm load and 775 with a 2 ohm load. 801d gets 800 w/ 2 ohm and 400 w/ 4 ohm. apart from that, i can't see a difference. and these are only off the 14.4 vdc. off 12 they are identical. |
| Posted on Monday, September 06, 2004 - 12:27 pm: |
Well, there are 2 small differernce 801D 100 damping factor $250-350 6500D 200 damping factor $150-250
| Posted on Tuesday, September 07, 2004 - 01:59 am: |
Anybody else? |
New member Username: A3forme
Post Number: 4 Registered: Sep-04
| Posted on Tuesday, September 07, 2004 - 11:49 am: |
Doesn't appear there's that much difference. The 801D is the newer model and the comression circuit to help keep from clipping..... |
| Posted on Tuesday, September 07, 2004 - 12:14 pm: |
I'm going to into getting a 6500D instead of the newer 801D. it's about a 50-100 dollars difference. Thank you for your input. |
