Thread: Hooking up Sub + Amp |
New member Username: 4twenty
Post Number: 1 Registered: Sep-04
| Posted on Sunday, September 05, 2004 - 11:46 pm: |
ok i have a logitech THX home theatre system, with the 400Watt sub, the fuse blew so now im just saving it for my car. the question is, would i be able to hook something mean for a computer up to a car?? the Sub box has a amp in it. |
Silver Member Username: Jayj
Louisiana
Post Number: 493 Registered: May-04
| Posted on Monday, September 06, 2004 - 12:19 am: |
It could work if you get a power invertor. But IMO I would buy real car audio equipment. |
New member Username: Pjrage
Post Number: 2 Registered: Sep-04
| Posted on Thursday, September 09, 2004 - 08:04 am: |
A horrible idea. Keep your computer speakers at your computer and get some real car audio stuff. If you absolutely have to do this (and have all your friends make fun of you ;)), JayJ is right, a power inverter will work. These can get a bit expensive. Make sure to spec the inverter such that its power matches the power requirements of your speakers (which can be pretty high). Overall, a really bad idea that will still cost you a pretty penny for a good inverter and won't sound nearly as good as the real deal. |
