Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > BOUGHT NEW CAR, TRYING TO HOOK UP AMP
Author Thread: BOUGHT NEW CAR, TRYING TO HOOK UP AMP
Username: Fortwynt
Charleston, WV
just bought a new 2005 tC and cant seem to locate any jacks on the back of the Head Unit (pioneer) to hook any RCA cables to with which to operate my amp which powers my two subs....any suggestions as to how I do this easily?
Username: Invain
Michigan
United States
Post Number: 106
First off you got a new head unit, right?
Username: Fortwynt
Charleston, WV
I have a new head unit that I had bought for my previoius car, which is actually a "better" stereo than the factory one in the new Scion tC...but I dont wanna get all into that right now with having to fill in all the gaps left due to the difference in size between the two and all that, I just figured there had to be SOME way to hook up the amp AND subs AND keep the factory stereo intact.
Username: Davids2004
Houston, TX
Post Number: 726
If ya wanna keep the factory radio you will need something called a hi lo converter. This will convert your speaker wire to allow you to run rcas to the amp.
Username: Pat_l
Tucson, AZ
Post Number: 522
http://www.tune-town.com/installation/line_out_reducers.asp
Here is what you need, what david said. Just tap it into your speaker lines, existing on the back of your deck.
Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > BOUGHT NEW CAR, TRYING TO HOOK UP AMP [ « Previous ] [ Next » ]
