Thread: Xtant amps? |
New member Username: Lostrookie
New Castle,
PA
United States
Post Number: 7 Registered: Aug-04
| Posted on Sunday, September 05, 2004 - 05:26 pm: |
are Xtant amps known to be powerful and durable amps? im trying to get the Xtant 403a for 3 JL 10w3 v2s (300 RMS each) but wasnt sure if it was 800 RMS of true power http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5718092518 |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 728 Registered: Jun-04
| Posted on Monday, September 06, 2004 - 10:52 am: |
I have the xtant A3001 amp and it does the job very well. Make sure to look at the max wattage and not the rms wattage. That amp is not gonna work for you becuase its a 3 channel amp which means its used for subs and speakers. If you do use it your sub channel would be giving one of the subs more power then the others and you would need a different configurations of ohm ratings to use that amp. By the way do you have the 2-4-6 ohm version of that sub. |
New Castle,
PA
United States
Post Number: 8 Registered: Aug-04
| Posted on Monday, September 06, 2004 - 06:39 pm: |
i have the 4 ohm version |
New Castle,
PA
United States
Post Number: 9 Registered: Aug-04
| Posted on Monday, September 06, 2004 - 06:50 pm: |
what do u think about this one, this guy told me i might need this but i duno about the watts and RMS and everything, i have no clue what would b compatable with those subs n i dont wanna waste my money http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39735&item=5718662829&rd= 1&ssPageName=WDVW
New Castle,
PA
United States
Post Number: 10 Registered: Aug-04
| Posted on Monday, September 06, 2004 - 07:00 pm: |
i found that xtant A3001 for cheap, wat subs do u have em hooked up to |
Houston,
TX
Post Number: 735 Registered: Jun-04
| Posted on Tuesday, September 07, 2004 - 09:37 pm: |
How much money are you looking to speond on an amp. Wiring those three subs together are gonna give you a 2.67 ohm load. What kind of box you gonna put them in. |
New member Username: Fishy
Post Number: 1 Registered: Sep-04
| Posted on Wednesday, September 08, 2004 - 09:14 pm: |
The 403a is not 800w rms and is not intended to drive 3 sub channels, just 1 at 200w into 2 ohms. Nah the 403a is designed to run an entire system, The specs the seller is claiming are fubar. The actual specs are 100x2, 200x1 into 2 ohms or see here:http://www.xtant.com/html/techSupport/pdfs/403aMan.pdf Don't get me wrong Xtant amps of this era are awesome(runnin my MB 215.6 Q's off a bridged 3180c, incredible) and this is a good price for this amp its just not what your application calls for. -Fishy |
Post Number: 2 Registered: Sep-04
| Posted on Wednesday, September 08, 2004 - 09:16 pm: |
[edit] "bridged 4180c" |
Houston,
TX
Post Number: 741 Registered: Jun-04
| Posted on Thursday, September 09, 2004 - 10:16 am: |
Lost rookie, Im pushing two orrion c series subs with them in a ported box and they do a real good job. |
