Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > JL Audio 1000/1 Question
Author Thread: JL Audio 1000/1 Question
ThatGuyYouKnow
1.ok when it says 1.5-4ohm load does that mean 1.5ohm 2ohm 4ohm loads?
2.also what will happen if I to wire 2 subs @ 2ohms on the same amp but diffent channels? will that create 4ohm load, or stay 2ohm load? and this will half(per chan) the RMS wattage?
Username: Johnnylemoine
LaPlace, Louisiana
United States
Post Number: 42
Go to jlaudio.com and read about their amps, it will tell you every thing you need to know. Those amps kick @$$.
ThatGuyYouKnow
dude it doesnt say thats why im asking
you dont think I woudnt do that already?
and I know they dont supply info on load impendance i was just wandering 2 2ohm would equal 4ohm load, i bet im wrong but need to know
Cuz id rather have each sub to this amp wired in @ 2ohm load.
but still does 1.5-4 mean every load between 1.5ohm and 4ohm? or just 1.5ohm or 4ohm operation?
LaPlace, Louisiana
United States
Post Number: 81
Yes dude every load in between, it says that.
Username: Jayj
Louisiana
Post Number: 494
It depends on your wiring. 2 2ohm subs could be wired a number of ways. But yes the JL 1000/1 is stable from 1.5 to 4ohms and it gives the same 1000 watts to any of those impendances.
Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > JL Audio 1000/1 Question [ « Previous ] [ Next » ]
