Home > Message Board > Car Audio > Subwoofers > Archives - 2004 > Archive through September 09, 2004 > MY TRUNK RATTLES, HELP ME!!!
Author Thread: MY TRUNK RATTLES, HELP ME!!!
JL.W6
i have a camry and my 12" JL DUB6 :-)
Username: Invain
Michigan
United States
Post Number: 95
Dynamat, Dynamat, Dynamat. If you don't want to spend that much, try eDead, you can order it cheap right off the elemental designs web site. My Sunbird trunk rattled worse than I've ever heard. I ordered 20 sq. ft. of eDead, and it worked like a charm.
JL.DuB6
thanx for info!
Username: Tom_k
Post Number: 18
Joe Smoe,you got any pictures of your Sunbird??? Thanks
DamnCrackhead
WTF you stupid idiot you don't have a JL dub6. It will be a Audiobahn Dub or a JL Audio W6. I think you need to get the f@ck off that damn CRACKPIPE.
DamnCrackhead you are a bit of a coward and by the sounds of things a lil computer geek!!
Get a real life
Username: Ne0nblakk
Post Number: 16
Aw, that's not cool. Why you have to get down on computer geeks?
Username: Johnnylemoine
LaPlace, Louisiana
United States
Post Number: 71
This place is so awsome, I love reading what you people say.
Username: Youngblood
Post Number: 43
actually there is stuff that is a lot cheaper than dynamat and does the exact same thing...its called like ice guard or something...its not made for car audio...made for roofing but in the end has the same effect...its a little thinner but you can put down 2 layers for half the price of dynamat and still have like 1/2 a roll left......its like $54 for like 108 sq feet...at least i think so...so if you dont wanna spend big money but in the end get the same effect...ice guard
Username: Jldub6
Post Number: 24
thx for info, i'll look into that :-)
Username: Ne0nblakk
Post Number: 25
I hear peel n seel does the same thing, also for some sort of roofing or weather sealing. Should be able to find it at hardware stores for cheap.
Home > Message Board > Car Audio > Subwoofers > Archives - 2004 > Archive through September 09, 2004 > MY TRUNK RATTLES, HELP ME!!! [ « Previous ] [ Next » ]
