Thread: What is the best amp for 2 Kicker S15L7 |
Bronze Member Username: Tylermoncrief
Post Number: 17 Registered: May-04
| Posted on Saturday, September 04, 2004 - 02:48 pm: |
I need to know whats a good amp to use...Thats under $400-475..And whats the best way to wire up the Subs to the Amp. And how much do you think someone should charge to hook it up |
Bronze Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 43 Registered: Aug-04
| Posted on Saturday, September 04, 2004 - 07:32 pm: |
Well i know that 1 RF power 501bd pusshes the $h!t out of my freind's 1 15L7. So one for each would be awsome, but i dont know if you can get two for 400-475. look on cardomain.com or etronics.com. Do it yourself. it aint that hard if you know alittle. also, wire their (if they are dual 4 ohm) voice coils in parallel to each amp. |
LaPlace,
Louisiana
United States
Post Number: 44 Registered: Aug-04
| Posted on Saturday, September 04, 2004 - 07:40 pm: |
the amps are 269.99 at etronics and cardomain dont carry them. soory maybe someone else knows about a good amp. |
LaPlace,
Louisiana
United States
Post Number: 45 Registered: Aug-04
| Posted on Saturday, September 04, 2004 - 07:48 pm: |
check out etronics P6001 600x1@ 2 ohms $379.99 P6002 600x1@ 4 ohms So 1200x1@ 2ohms $389.99 Should be enough dont know too much bout these new amps but last year power models rock. A power 1001bd would be good. try to find that if you like RF. |
Bronze Member Username: Heavyb
Hopkins,
Sc
Usa
Post Number: 80 Registered: Jul-04
| Posted on Saturday, September 04, 2004 - 09:58 pm: |
kicker 1200.1 might not be enough power though hifonics brutis 1500 or mtx 1500 best would be mtx |
Post Number: 18 Registered: May-04
| Posted on Sunday, September 05, 2004 - 04:36 pm: |
Anyone else, has any decisions...Do you think I will need to bridge it...Or what? |
