Thread: 350W RMS "D" Amp for 10" Infinity sub ? |
Rick H. Unregistered guest |
| Posted on Thursday, September 02, 2004 - 11:32 pm: |
I'm adding a sub and amp to my SUV stock system. I've decided on the Infinity Kappa Perfect 10" sub. I can order either SVC (4 ohm) or DVC (2 or 8 ohm). The specs on the sub recommend 350W RMS power. Any recc's on a mono "D" amp for under $400 to provide power ? Since I don't think I'm ever going to add a second sub, probably a 2 ohm, 350+ Watt amp is what I'm looking for.
Silver Member Username: Davids2004
Houston,
TX
Post Number: 702 Registered: Jun-04
| Posted on Saturday, September 04, 2004 - 11:26 am: |
I would go with a dvc 4 ohm sub and look on ebay for the xtant A3001. You can get it for 100.00 shipped and it will give you 300 rms at 2 ohms and will work perfect for ya. |
Bronze Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 40 Registered: Aug-04
| Posted on Saturday, September 04, 2004 - 11:52 am: |
FR power 351m, should be around $200 shipped. |
