Thread: SVC or DVC??? |
Bronze Member Username: Nysteelers
Post Number: 33 Registered: Aug-04
| Posted on Thursday, September 02, 2004 - 05:09 pm: |
i have a 96 pathfinder and am looking to buy 2 12" cerwin vega vmaxes. Im planning to hook them up to a jbl 600.1. Do i buy the SVC or DVC, and whats the difference?? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13949 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13950 |
Post Number: 34 Registered: Aug-04
| Posted on Thursday, September 02, 2004 - 06:41 pm: |
oops sry i posted this in the wrong place |
Silver Member Username: Caraudiofng
Houston,
TX
Post Number: 235 Registered: Aug-04
| Posted on Thursday, September 02, 2004 - 06:53 pm: |
To keep the Amp more efficient and cooler, get the 2 SVC 40hm subs. That will put a 2ohm load on the amp, and put 300w a piece to the subs. |
Post Number: 36 Registered: Aug-04
| Posted on Thursday, September 02, 2004 - 07:27 pm: |
ok tnx |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 704 Registered: Jun-04
| Posted on Saturday, September 04, 2004 - 11:28 am: |
either two svc 4 ohm or two dvc 2 ohm. Either one will give you a 2 ohm load on the amp. |
