Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > Kicker vs. hifonics
Author Thread: Kicker vs. hifonics
Username: Neonsound
Usa
Post Number: 20
which is better and what subs would you recomend that will hit hard and loud
Username: Neonsound
Usa
Post Number: 21
i am compairing the brutis 1500.1 and the kicker 1200.1
it's pretty close, assumming that you going to do 1ohm load? I would go with the 1500.1D, Maybe little it more power very close (kicker's little bit under-rated) and draws less than the kicker.
Visitor#78
Well, the Kicker is better in my opinion. And if it helps any, all the Kicker 1200.1s I've seen are tested at over 1400w RMS 2ohms. But Hifonics is a pretty good cost saving option.
Username: Neonsound
Usa
Post Number: 22
what would be a good sub match for the kicker 1200.1
1400rms @ 2ohms?? maybe @ 1ohm? That's very good if it's true. It's rated at 600x1 @ 2ohms for the 1200.1, if I'm not wrong. Kicker are underrated at most of the time.
Visitor#78
You're correct, I appologize....thinking of JBL BP1200.1 1200w at 2 or 1 ohm. This, if you can find it, is also a good option.
Visitor#78, not need for apologize, we all make mistakes. I read many of your thread here, your words is very thoughful.
Username: Jonathan_f
GA
Post Number: 1474
Kicker amp is built better and has better SQ. Hifonics is a good cheap alternative, but personally I'd do a JBL 1200.1. Less iffy in my opinion, I've heard mixed opinions on Hifonics.
Home > Message Board > Car Audio > Amplifiers > Archive through September 12, 2004 > Kicker vs. hifonics [ « Previous ] [ Next » ]
