Thread: No power remote wire |
New member Username: Dvdj
Oh
Post Number: 1 Registered: Aug-04
| Posted on Thursday, September 02, 2004 - 10:38 am: |
Hi I don't have a power remote wire on my new deck I have a power antenna can I hook the power remote wire to the amp to that or should I go straight to the ignition wire thanks:dvdj |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 518 Registered: Apr-04
| Posted on Thursday, September 02, 2004 - 12:00 pm: |
I would go to the IGN or ACC fuse. |
Bronze Member Username: Koz1031
Monticello,
In
United states
Post Number: 77 Registered: Jul-04
| Posted on Friday, September 03, 2004 - 05:25 am: |
If it's an unused wire (not hooked to a power ant.) Yes, this IS the remote wire. It's blue I imagine. so that goes to the remote on the amp. if it is connected to a power ant. then go ahead and do as Pat suggested. |
Gold Member Username: Jonathan_f
GA
Post Number: 1497 Registered: May-04
| Posted on Friday, September 03, 2004 - 11:47 am: |
Do the antenna, that way the amp will turn on with the antenna instead of every time you cut your car on. |
Bronze Member Username: Stugots
Post Number: 28 Registered: May-04
| Posted on Saturday, September 04, 2004 - 09:03 am: |
If your car is a pontiac Grand AM 2001 then you ahve to goto the Igintion wire thats what i had to do with my car |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 701 Registered: Jun-04
| Posted on Saturday, September 04, 2004 - 11:23 am: |
Is this an aftermarket deck or factory? If its aftermarket look for the blue wire with a white stripe. |
