Thread: Sub Out on Head Unit |
| Posted on Tuesday, August 31, 2004 - 09:55 pm: |
I just bought and installed a JVC KD-G800 head unit in my 93 Explorer.It has a sub out connection on the back so you can control the sub from the head unit but the output is only rated at 2.0 volts,but the line out connections are rated at 4.0 volts wich would be better to connect my JBL GTO601.1 mono amp to? Thanks Rick. |
Bronze Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 78 Registered: Jun-04
| Posted on Monday, September 13, 2004 - 10:06 pm: |
4 volt would be better, but since it is going to your sup you might not notice a diffrence. I would try it on both and just see what sounds better. |
New member Username: Thedirk
Potsdam,
NY
Post Number: 7 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 10:39 pm: |
yea try both and pick the best, thugh ive always had best results with the regular low output, the dirk, |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 132 Registered: May-04
| Posted on Saturday, September 18, 2004 - 11:12 pm: |
the voltage level on preamp outputs are just for signal stregth, use the one thats designated for your subs. that output most likely will give a crossover plus that output is non fading, so when you adjust your treble and bass from the head unit it wont mess with the performance of your sub. |
