Thread: Can i connect 2 amp grounds to 1 screw |
Bronze Member Username: Cocotaso
Queens,
Ny
Post Number: 18 Registered: Aug-04
| Posted on Tuesday, August 31, 2004 - 11:54 am: |
also when i put the level up on my amp it goes into protect mode...any help would be great.. the amp wit the problem is being bridge |
Queens,
Ny
Post Number: 19 Registered: Aug-04
| Posted on Tuesday, August 31, 2004 - 12:25 pm: |
please help i would like to go do this at lunch |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 517 Registered: Apr-04
| Posted on Tuesday, August 31, 2004 - 12:50 pm: |
Yes, you can connect them but if you could i would seperate them. |
Queens,
Ny
Post Number: 21 Registered: Aug-04
| Posted on Tuesday, August 31, 2004 - 12:56 pm: |
there are no screws in my trunk only this 1 big bolt that i can fit them both on....or can i get a screw with a washer and put 2 on the wheel well..thx for the response |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 112 Registered: May-04
| Posted on Tuesday, August 31, 2004 - 04:25 pm: |
Pat was right its better that you seperate them yes u can use a srew with a washer, if you can the best place i use for grounding is the big srew that holds the rear seat belts in place. |
Queens,
Ny
Post Number: 26 Registered: Aug-04
| Posted on Wednesday, September 01, 2004 - 11:31 am: |
thx |
