Thread: Amp from a factory deck |
New member Username: Fastlivn18
St. thomas,
Virgin islands
Us
Post Number: 1 Registered: Aug-04
| Posted on Tuesday, August 31, 2004 - 12:30 am: |
i have a factory deck in a 1999 oldsmobile alero. i want to hook up an amp for a 10" MTX sub. i need to know how i would go about wiring it up. i would probably have to run high level inputs because i have no rca outputs. the only problem now is that i cant figure out how to get the control wire to turn the amp on. how do i get the amp to power on without the wire from the reciever? |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 515 Registered: Apr-04
| Posted on Tuesday, August 31, 2004 - 12:43 am: |
Go to your Fuse boxes, I like to use the ACC (accesory) or the IGN (ignition) fuses for my remote wire. Just make sure the one you pick will shut off when the car is off, because some have constant power, which in turn will drain the battery in hours. |
St. thomas,
Virgin islands
Us
Post Number: 2 Registered: Aug-04
| Posted on Tuesday, August 31, 2004 - 12:01 pm: |
thanx. i will try that and see if i can wire up my stuff. i appreciate it. |
