Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > Need help: mono amp and two DVC subs
Author Thread: Need help: mono amp and two DVC subs
Username: King_drifter
Kingston, TN
I have an MA audio 800w mono block amp and two pioneer 12" premier dvc 1000w peak subs. I turn my volume up past a certain point and my subs cut out. I need the best wiring setup for the subs. I'm not sure how they are wired up now as i didnt do the install. Tell me what to do.
ThatOneGuy04
You get what you pay for.....
Username: Davids2004
Houston, TX
Post Number: 690
If you have the dvc 4 ohm subs you proably have them wired at 1 ohm. The best you can get if you have the dvc 4 ohm is a 4 ohm load on that amp. In order to get the quality out of that amp you would need the dvc 2 ohm version. Sorry.
Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > Need help: mono amp and two DVC subs [ « Previous ] [ Next » ]
