Thread: Head unit wiring |
New member Username: Carr16v
Post Number: 3 Registered: 12-2003
| Posted on Monday, December 29, 2003 - 02:43 pm: |
Hi,I,ve just finished wiring in my amp to the car. I have a sony head unit and I've used the blue wire to control the amp on and off. Problem is the amp only works with the radio on. When I change the source to cd or tape the power is turned off to the amp. I know that this wire can also be used to power the electric aerial. So I'm thinking thats set to power an aerial, so that when I change from radio it turns power off to let the aerial back down. Is there a way around this. I put my JVC headunit in and works fine. Can anyone shed some light on the situation. Many Thanks Keith Carr |
New member Username: Glasswolf
Post Number: 397 Registered: 12-2003
| Posted on Monday, December 29, 2003 - 04:04 pm: |
you used the wrong wire. use the "remote" wire not the "power antenna" wire to trigger the amplifier. problem solved.
Post Number: 4 Registered: 12-2003
| Posted on Tuesday, December 30, 2003 - 03:06 am: |
Can you tell me what wire or colour this wire is? I don't have a wiring diagram for it anymore. |
Post Number: 420 Registered: 12-2003
| Posted on Tuesday, December 30, 2003 - 11:55 am: |
power antenna is blue remote is blue with white trace or vice versa. I forget on Sony.. I try to avoid anything they make.
jay amaro Unregistered guest |
| Posted on Tuesday, December 30, 2003 - 12:31 pm: |
it should be the other blue wire coming out the back of the stereo. this is true for most aftermarket decks but i know sony's for a fact have a solid blue for rem antennae which you are currently hooked onto and there should be another blue one with a white stripe and thats for the rem amp turn on and thats the one you really want. jay |
| Posted on Tuesday, December 30, 2003 - 12:55 pm: |
