Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > Getting the most out my amp..thx for ...
Author Thread: Getting the most out my amp..thx for help
Username: Cocotaso
Queens, Ny
Post Number: 8
i have 2
Kicker C12/4 - Comp 12" Subwoofer 4ohm
Key Features:
polymineral cone
double-stitched polyester foam surround
can be used in free-air applications
frequency response 27-500 Hz
power range 40-150 watts RMS
peak power handling 300 watts
sensitivity 88.6 dB SPL
top-mount depth 5-5/8"
sealed box volume 1.25-3.5 cubic feet
ported box volume 1.75-2.25 cubic feet
1-year warranty
running off a
PRODUCT FEATURES:
800 Watts X 2 Output;
1600w X 1 Bridged Output;
Variable Hi/Lo Electronic Crossover Network;
Variable Bass Boost (0 - +18db @ 60hz);
Variable Input Level (Gain) Control;
Remote Turn On/Off;
Gold Plated RCA Inputs;
High Level Molex Input;
Power On Led Indicator;
Led Protection Indicator;
Blue Led Scanning Illumination;
Remote Bass Boost;
S/N Ratio: > 95db;
THD: < 0.04%;
Thermal Protection;
Overload Protection;
Short Circuit Protection;
Anti-Thump Turn-On.
any help would be apprciated
Username: Davids2004
Houston, TX
Post Number: 693
By not knowing what the rms is on that amp or what kind of box im gonna say your giving it way too much power. Those subs are only 150 rms a piece. A couple of amps I would look at would be the xtant A3001 (100.00 shipped on ebay brand new), P3001, JBL 300.1.
Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > Getting the most out my amp..thx for ... [ « Previous ] [ Next » ]
