Thread: KICKER KX1200.1 Over Kill???? |
Bronze Member Username: Stugots
Post Number: 21 Registered: May-04
| Posted on Sunday, August 29, 2004 - 07:48 pm: |
Interested in getting this KICKER KX1200.1 im getting 2 10" Alpine DVC 2 ohm Subs would this amp be overkill if i were to wire them in 1 ohm? |
Silver Member Username: Caraudiofng
Houston,
TX
Post Number: 172 Registered: Aug-04
| Posted on Sunday, August 29, 2004 - 08:08 pm: |
I think that is way overkill. The KX600.1 would be plenty. Wire them down to 2ohms (which you can do with these subs). I wouldn't go with the KX1200.1 unless you used the Type X sub |
Post Number: 22 Registered: May-04
| Posted on Sunday, August 29, 2004 - 08:11 pm: |
Perfect what about the Memphis M-Class 16-MC500D???.. Are Memphis high quality amps? |
Houston,
TX
Post Number: 173 Registered: Aug-04
| Posted on Sunday, August 29, 2004 - 08:17 pm: |
Memphis is quality, but it's 100 less watts than the Kicker, but if you're going ported, the Memphis should be fine also. |
Post Number: 23 Registered: May-04
| Posted on Sunday, August 29, 2004 - 08:19 pm: |
Excellent, Ok so what would you get? if i were to get the Kicker would a sealed box do the job?.. And same goes for the memphis a sealed box would do it but obviously with 100watts less it wouldnt pound as much?? |
Houston,
TX
Post Number: 174 Registered: Aug-04
| Posted on Sunday, August 29, 2004 - 08:36 pm: |
Right. I would do the Kicker, get full potential out of the sub. |
Post Number: 24 Registered: May-04
| Posted on Sunday, August 29, 2004 - 09:12 pm: |
Well i couldnt find a Kicker amp 600.1 so i bid on the memphis and won :D $183.12 U.S. for a 500.1 it should do the job fairly well :D |
Visitor#78 Unregistered guest |
| Posted on Sunday, August 29, 2004 - 10:00 pm: |
Got a good deal, nice amp. |
Silver Member Username: Its_bacon12
Hfl,
Ny
Usa
Post Number: 999 Registered: Dec-03
| Posted on Sunday, August 29, 2004 - 11:27 pm: |
wow thats an awesome deal on the memphis |
Post Number: 25 Registered: May-04
| Posted on Friday, September 03, 2004 - 05:23 pm: |
Ok i got my memphis amp hooked it up and WOW what an amp!.. im impressed but my question is the manuel suggests a 8gauge wire should i get a 4 gauge or do what the manual suggests? |
Bronze Member Username: Jtb
Post Number: 93 Registered: Jun-04
| Posted on Friday, September 03, 2004 - 10:11 pm: |
The kicker 1200 will really put out about 1300-1500 watts easy, they underrate their amps. How long is the wire from the battery to the amp? You will only need an 8g unless it is unusually long, but if you plan to hook up another amp for components I would go ahead and get a 4g to save time and money. |
Visitor78 Unregistered guest |
| Posted on Saturday, September 04, 2004 - 10:10 am: |
Stugots, I would still use 4 gauge, it's not going to hurt anything... |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 698 Registered: Jun-04
| Posted on Saturday, September 04, 2004 - 11:20 am: |
Yea do 4 gauge. More is alwasy better. Also I would port those subs and they will really get loud. |
