Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > 2 Alpine Type-R 10" 2 ohm
Author Thread: 2 Alpine Type-R 10" 2 ohm
Username: Andysila
i have 2 of the 10" type-r.. what amp,box,and wiring would you suggest?
TREY
Get an enclosed box they will hit harder.get a 500 watt wiring kit. As for the amp, How Many Watts Are They? A 600 watt amp would work just fine If they are 250 rms.
Username: Andysila
i was thinking the Alpine MRD-M501.... would that be good? i got a 2000 honda civic... which box would be best, bandpass?
Trey
Yes that would be an excellent amp That requires 4 gauge wiring kit Sealed enclosure would hit way harder. the bandpass box will hit too but not as much as the sealed box.
Username: Andysila
where can i get the box and which brand/model do you recomend? and will i need a new alternator if i dont want the lights to dim ?
Username: Its_bacon12
Hfl, Ny
Usa
Post Number: 1001
bandpass is awful for quality sound, seriously...it has spiked frequencies for SPL but it rolls off HORRIBLY below the tuning frequency and it just sounds absolutely horrid
sealed is reccomended for type-r's but a ported box built to specs is always the loudest for the amount of power you put into the driver
Username: Andysila
so what do you recommend i get all together ?
Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > 2 Alpine Type-R 10" 2 ohm [ « Previous ] [ Next » ]
