Thread: What are the advantages of a Mono amp over 2 channel? |
Bronze Member Username: Stugots
Post Number: 19 Registered: May-04
| Posted on Sunday, August 29, 2004 - 11:48 am: |
Subject says it all :D "What are the advantages of a Mono amp over 2 channel?" |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 674 Registered: Jun-04
| Posted on Sunday, August 29, 2004 - 01:17 pm: |
Amplifier Classes There are five main amplifier designs: Class A, A/B, B, D, and Tube amplifiers. All of these but tube amplifiers are considered "solid-state." Class A amplifiers are the most sonically accurate. On the other hand, they have some drawbacks that make them not be the most common choice. Class A amplifiers use only one output transistor that is turned "on" all the time, giving out tremendous amounts of heat. Class A amplifiers are very inefficient (~25%). More heat means more heatsink area, so even though most class A amps have built-in cooling fans, they are big. Pure class A amplifiers are usually expensive. Class B amplifiers are the most common and use two output transistors. One for the positive part of the cycle and one for the negative part of the cycle. Both signals are then "combined". The problem with this design is that at the point when one transistor stops amplifying and the other one kicks in (zero volt line), there is always a small distortion on the signal, called "crossover distortion". Good amplifier designs make this crossover distortion very minimal. Since each transistor is "on" only half of the time, then the amplifier does not get as hot as a class A, yielding to a smaller size and better efficiency (~50%). Class A/B amplifiers are a combination of the two types described above. At lower volumes, the amplifier works in class A mode. At higher volumes, the amplifier switches to class B operation. The class D amplifier (known as digital amplifier) is the last of the solid-state types. These amplifiers are not really digital (there is no such thing), but operate similarly in manner to a digital-to-analog converter (DAC). The signal that comes in is sampled a high rates, and then reconstructed at higher power. This type of amplifier produces almost no heat and is very small in size. Efficiency is much higher in class D amplifiers (~80%). The sound quality of a Class-D amplifier is much lower than that of other solid-state amplifiers, which is why Class-D amplifiers are only used for subwoofers in car audio. This is because the switching speed of the transistors, and lower sound quality are masked by the lower frequencies being reproduced by the subs, since distortion is harder to discern at low frequency. Lastly we have tube amplifiers, which aren't often used in car audio. Tube amplifiers have about 50 to 60% efficiency. Tube amplifiers are said to sound more musical. The reason is that tube amplifiers produce even ordered harmonics. Musical instruments give off harmonics in even orders. Transistor amplifiers tend to give off harmonics that are odd ordered. These harmonics are not pleasing to the ear as second order harmonics are. Modern solid state amplifiers have very low distortions but their distortions are less tolerated by the ear than even ordered harmonics. This means that when you hear someone say a Tube amp is "warm" sounding, they are actually talking about the second order distortion produced by that tube amplifier, which they find pleasing to the ear. A good example of this is in guitar amplifiers, which often pride themselves on their second order harmonics. One should note that while most solid state amplifiers have very low distortions (Total Harmonic Distortion) for the left and right channel, other channels are often much higher as these specifications are rarely noted. Subwoofer amplifiers are particularly bad at creating odd ordered harmonics. I believe that the best tube and solid state amplifiers sound amazingly alike. Bad tube amplifiers sound tubby and slow. Bad transistor amplifiers sound harsh, bright and strident. Just like you can't judge a good book by its cover, you can learn very little about an amplifier without digging in and seeing what is inside. Generally speaking, the most important component of any amplifier is its power supply. Is it sufficient? Is it accurate? Is it fast? Unfortunately, almost no amplifier company talks about their power supplies or what transformers they use (An example of a good company would be Eclipse, who uses dual toriodal transformers in their amplifier power supplies.) I think most manufacturers would prefer you not ask.
Post Number: 20 Registered: May-04
| Posted on Sunday, August 29, 2004 - 03:07 pm: |
Ok Thanks, also Mono and Stereo with subs explain is there a difference in the sound or how does it work?. |
Houston,
TX
Post Number: 680 Registered: Jun-04
| Posted on Sunday, August 29, 2004 - 06:19 pm: |
Hooking up subs in stereo or mono will not make a difference in sound quality or power output. If you hook them up in 2 ohm stereo mode it will sound the same if you could bridge them at 4 ohms. |
Gold Member Username: Jonathan_f
GA
Post Number: 1372 Registered: May-04
| Posted on Monday, August 30, 2004 - 12:47 am: |
With stereo, you'll just get channel separation as a stereo signal, the left sub will play the left channel, and the right the right channel. You want a sub to be in mono ideally, especially since it's in the rear of the vehicle, so you need to bridge the amp for this, this combines both channels for one mono signal. Sound quality actually degrades a tad with a bridged load, not nearly as bad as a Class D amp, but it's worse than a stereo 2 ohm load, distortion and damping, etc. is worse. Whether it's noticeable or not depends on the amp. Basically, just like above, Class D equals less current draw, and a smaller and cheaper amp for the power, less heat output. Also equals worse sound quality. |
