Thread: MTX vs. Hifonics vs. Kicker |
Bronze Member Username: Blindc1rca
Post Number: 61 Registered: Aug-04
| Posted on Saturday, August 28, 2004 - 09:28 pm: |
Im getting two Cerwin Vega V-max 10's, they have 200w RMS each. Ive narrowed it down to three amplifiers, please tell me your opinion on which is the best: MTX 421D http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5716361216&rd= 1&ssPageName=WDVW Hifonics Warrior Merlin 450D http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5717261353&rd= 1 Kicker KX400.1 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5717279068&rd= 1&ssPageName=WDVW |
Bronze Member Username: Youngblood
Post Number: 34 Registered: Aug-04
| Posted on Sunday, August 29, 2004 - 12:09 am: |
i like kicker and MTX......i like the kicker more though just because of what i have heard from people and from my friends systems....so i dunno ...another plus is(i think) that amp has the little controls on top and a little screen that would seem like it would be a little more user freindly |
Silver Member Username: Caraudiofng
Houston,
TX
Post Number: 160 Registered: Aug-04
| Posted on Sunday, August 29, 2004 - 12:30 am: |
The Kicker would be best, but the MTX would be good too. |
Post Number: 75 Registered: Aug-04
| Posted on Sunday, August 29, 2004 - 05:10 pm: |
if i had 2 4 ohm DVC subs could I wire them to a to ohm load? |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 677 Registered: Jun-04
| Posted on Sunday, August 29, 2004 - 06:15 pm: |
If you have 2 4 ohm dvc that will give you either a 1 or 4 ohm load. At that time go with the hifonics which is 450 rms at 1 ohm. With those subs the hifonics is really your best choices. If your going sealed you may also want to look at the hifonics brutus bx500 |
