Home > Message Board > Car Audio > Head Units > Archive through October 04, 2004 > Head unit doesn't work
Author Thread: Head unit doesn't work
Wario
I put in a new HU worked fine. I go to put in old one doesnt work but the light is blinking on it. I take the black wire (grounding), and I touch some metal and it sparks, so there is power runnning. I go to put new HU in again, and that stopped working also. I'm thinking maybe a fuse?? Any Suggestions?
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 81
Check the fuses, on the radio and in your car. I bet they are blown. I am also going to guess your old stereo has a protection mode that has triped and thats why it wouldn't work when you put it back in.
Home > Message Board > Car Audio > Head Units > Archive through October 04, 2004 > Head unit doesn't work [ « Previous ] [ Next » ]
