Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > What amp should i use????
Author Thread: What amp should i use????
Username: Cravis85
if i got a kicker solo baric 04215l7 and it was a dual 4 ohm 18-100hz 75-1000rms and 2000 peak which am would go good with that to really make it pound
Username: Joe718
Brooklyn, NY
Post Number: 106
try the rockford fosgate 1001bd it will give you 1000 watts rms. look for the the 2002 modle the amp is grey and the Rockford symbol is blue. i dont know much about there newer models but that one should work fine
Username: Ctx
Post Number: 38
kicker 800.1
loui
really pound? the soundstream rubicon 1000/2 PURE 1000 rms!) or the power acoustic amp's.
Username: Davids2004
Houston, TX
Post Number: 691
hifonics bx1500.
Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > What amp should i use???? [ « Previous ] [ Next » ]
