Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > Would this work?
Author Thread: Would this work?
Username: Nysteelers
Post Number: 10
would this combination work?
(JBL BP600.1 Amp) http://www.audiodiscounters.com/product_id/267.html
with 2 Cervin Vega 15" V-max subs, im not sure which model to get because i dont know the difference between the V-MAX15SVC and the V-MAX15DVC http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13952
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13951
would that amp be enoguh for those sbs, and could i include door speakers with-out buying another amp? ANd would this combo pound? Thanks
Username: Jonathan_f
GA
Post Number: 1327
That amp should be enough, they're underrated. Get the SVC subs so you can run a 2 ohm load. You can't run door speakers off that amp, it's strictly a mono subwoofer amplifier. You'll need an external amplifier, or some door speakers that will work well with the head unit.
GA
Post Number: 1328
Oh, and yes that combo will hit hard.
Post Number: 11
awsome ..im probly gunna get that when i get my car this weekend...and i could always add another amp and speakers at a later date right?
GA
Post Number: 1329
Absolutely.
Post Number: 12
nice..and how much would an audioshop cost for installation typically?
Post Number: 13
oh and u think if i had 3 of those V-MAX15DVC 15' subs..that would be too much for that amp?
GA
Post Number: 1330
3 VMaxes would be too much for that amp, the 2 you'll have may be a tad underpowered, but not by much. I recommend a JBL 1200.1 for 3 15" VMaxes. It depends on a couple of things in determining how much the cost will be, like if they're building the box or you, plus audio shops have many different rates, especially ones with MECP certified installers (you better get one with an MECP certified installer, don't go somewhere cheap like Best Buy or Circuit City, they do horrible installations) I advise you to just go find costs around you and see who is the cheapest.
Post Number: 14
alright thanx alot.. u really cleared sum stuff up 4 me
Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > Would this work? [ « Previous ] [ Next » ]
