Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Car monitor in home
Author Thread: Car monitor in home
jason howie
ok i have a 7" tft lcd screen in my car. i want to hook it up in my dorm room. it has 2 wires, red for power and black for ground. if i were to buy an AC to DC power converter, could i hook up the tv in my room? could i connect the 2 wires to a 12 volt cigarette plug and just plug it into there? the only thing im not sure about is if "positive-negative" is different than "positive-ground"
anyone know if this would work or not?
any help would be appreciated...thanks.
jason howie
also, is there a cable that converts the cable tv cable into a video rca, or an s video cable?
Dude buy a real TV that goes in your house. Car audio equipment is called CAR AUDIO for a reason it goes in your CAR not a dorm room.
jason howie
thanks for no help at all. why did you even post? that was the most useless, helpless comment i have ever seen.
this is a cool project for people that are interested in electronics. someone that knows electronics please help.
Username: Pat_l
Tucson, AZ
Post Number: 501
I agree, Car Audio is named Car audio for a reason.
jason howie
thats just cause you know nothing about electronics so you say that. what is so bad about converting it? is it cause you know nothing about electronics?
Username: Jayj
Louisiana
Post Number: 473
Well I know quite abit about Car Audio and I agree with Pat and Anonymous. You need to buy a house television not a car tv. What you are wanting to do is like hooking up a car sound system in your house. Just go out and buy a 13" TV for 80 bucks at WalMart. And once again CAR AUDIO IS FOR YOUR CAR NOT HOUSE OR DORM ROOM.
jason howie
you guys are f-cking g-y. straight up. no help what so ever.
Well try buying a home TV you f*cking DUMBASS you want to talk sh!t but you want to put car audio in a damn dorm room. Get a damn job and buy a 13" TV like Jay said.
jason howie
how bout you take that 13" tv and shove it into my bottom hole
youre such a plug and player
Username: Topedgeonline
Montrose, Colorado
United States
Post Number: 18
Here is what you need:
http://www.topedgeonline.com/detail.aspx?ID=2853
This is the same power supply I use to test used Car CD players.
Ground and negative are the same thing as far as this goes. This power supply has a positive and negative post as well as a cigarette lighter input.
jason howie
thanks man i appreciate it. i just bought it. hope it all works out
Username: Ps1k0
Post Number: 14
you could also use a computer power supply. if you have one lying around.
use one of the cords that would goto a hdd cut off and use the yellow for 12+ and a black for gnd.
StupidIdiot
LMAO Jason you got RIPPED!!! You could have got that POS for 12 bucks shipped
Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > Car monitor in home [ « Previous ] [ Next » ]
