Thread: 4 speakers 2 channel amp |
New member Username: Cocotaso
Post Number: 1 Registered: Aug-04
| Posted on Thursday, August 26, 2004 - 11:07 am: |
hey im new to the game and i was wondering if i can put 2 front 5 1/4 xplodes and 2 back 6x9 pioneers on a 2 channel pyle amp...thx for the help |
Bronze Member Username: Joe718
Post Number: 100 Registered: May-04
| Posted on Thursday, August 26, 2004 - 11:59 am: |
you could but the sound might be crappy, first you have to see what kind of load your amplifier can handle and the load of your speakers. if every speaker is 4 ohm and if the amp is 4 ohm per channel which it most likely is. run your front speakers in series to a channel and do the same to the rear. but check everyting out b4 you do this. use this link to help you out, when you find out the inpedance fo your system. http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Single+Voice+Coil+-+4+ohms&image.x=7&image.y=6 |
Post Number: 3 Registered: Aug-04
| Posted on Thursday, August 26, 2004 - 12:17 pm: |
this is for the 6x9...Mounting Depth: 3-3/8" Tweeter Protrusion: 7/8" Sensitivity (Efficiency): 93dB (1W/1m) Frequency Response: 25 - 32,000Hz Impedance: 4 ohms this is for the xplodes...Subwoofer Size 5-1/4" Resistance (Ohms) 4 ohms Bottom Mount Depth (inches) 1-13/16" Tweeter Design 7/16" dome Tweeter Composition PEI film balanced dome Peak Power Handling 200 watts rms 75 and the amp is....Pyle Elite Series #PLA2480 - 1600 Watt 2-Channel Power Amp * Max 800 Watts x 2 Output * RMS 125 Watts x 2 Output @ 4 ohms * RMS 180 Watts x 2 Output @ 2ohms * Max 1600 Watts x 1 Bridged Output * RMS 250 Watts x 1 Bridged Output * Variable Hi/Lo Electronic X-over Network * Variable Bass Boost ...................................... any help would be great im trying to run the insides on tis amp...thx for the help already
Queens,
Ny
Post Number: 4 Registered: Aug-04
| Posted on Thursday, August 26, 2004 - 03:08 pm: |
some help please i woould really like to do this today.....thank you for your help |
