Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > What does a capacitor do?
Author Thread: What does a capacitor do?
Username: Blindc1rca
Post Number: 27
I think I need to get a capacitor for my setup (2 VMAX's and a Hifonics Nemesis 750D). I dont know too much about powering my amp but I do know that my car battery probably wont do it by itself, so if you could let me know what I need thatd be awesome
Username: Davids2004
Houston, TX
Post Number: 664
Capacitors are usually a waste of time. It has been known to actually hurt your cause rather then help it. Basically what a cap does it stores energy and releases it when your battery and alternator can provide enough power. Your best bet would be a high output alternator.
Username: Pat_l
Tucson, AZ
Post Number: 485
Basically what davids2004 said, but why you would want energy stored? You want that extra energy stored because when the subs hit, in some cases (depending on song) the subs will hit real hard, then back off, then hard again- so on and so forth (rap music). So a cap will allow the system to take that energy with out 'punshment' to the battery. Because when a song hits like that the energy just gets sucked out of the battery at a high level, then again and again (as the song progresses. Then the Altenator cant keep up with the batterys fast discharge and need of power, and like wise the battery cant keep up with the cap and amps need. So the system dies. The thing is about caps. If you dont have a good (powerful) alternator and mabey a tuff battery (optima) then a cap will just suck the juice out of everything- making the situation even worse. Because now you got more system drain because the cap needs a minute or two to charge, everytime the car is started. So now your car has one more thing to power. A cap is probably the VERY last thing you would put into any system.
Username: Glasswolf
NorthWest, Michigan
Post Number: 4467
http://www.wickedcases.com/caraudio/capacitors.html
http://www.wickedcases.com/caraudio/charging.html
Home > Message Board > Car Audio > Amplifiers > Archive through September 01, 2004 > What does a capacitor do? [ « Previous ] [ Next » ]
