Thread: Is this possible? |
New member Username: Franksta
Post Number: 1 Registered: Aug-04
| Posted on Wednesday, August 25, 2004 - 02:13 pm: |
Hello, I got a brand new car about a month ago, and I'd like to put my amp and subs in it. However, If at all possible, I'd rather not take out the factory stereo or even bother with taking anything apart on the dash, etc. A friend of mine mentioned that he thought there was some kind of item I could buy that would allow me to splice into my back speakers and not steal any of the wattage. He also said I would be able to hook up my RCA cables to this mystery item and connect them to my amp. Does such an item exist? Or was my friend just making up stories? Thanks for any help you may offer. |
NorthWest,
Michigan
Post Number: 4462 Registered: Dec-03
| Posted on Wednesday, August 25, 2004 - 11:39 pm: |
most sub amplifiers have high level inputs that will take speaker level inputs and use them as a signal for the amp. you can do this externally as well using a "LOC" or line-out converter. (line reducer) any car audio shop sells these
New member Username: Topedgeonline
Montrose,
Colorado
United States
Post Number: 1 Registered: Sep-04
| Posted on Wednesday, September 01, 2004 - 10:58 pm: |
Here is a link to the product you would need: http://www.topedgeonline.com/detail.aspx?ID=8113 Works great. We sell a lot of these on ebay at this same price $9.99 with free shipping. GlassWolf was right. A lot of amplifiers will have a high level input. If it doesn't I would go with the item I mentioned above. |
