Thread: Multi subs |
New member Username: Newb
Post Number: 26 Registered: 12-2003
| Posted on Thursday, December 25, 2003 - 03:06 pm: |
jus wondering if u run 2 subs can u use a 2 channel to run one and a mono amp to run the other or does it matter? |
New member Username: Josh_heller
Post Number: 5 Registered: 12-2003
| Posted on Thursday, December 25, 2003 - 03:15 pm: |
you can use the 2 channel bridged to run one sub and the mono to run the other. what kind of amps are talking about? the thing is, there will be 2 different amps playing the same music into 2 subs, and chances are the 2 channel is not a sub specified amp, so you will have 2 different sounding subs that are playing the same music. i dont recommend it. |
Post Number: 27 Registered: 12-2003
| Posted on Thursday, December 25, 2003 - 04:04 pm: |
oic, music quality will be different with 2 different amps. just bought a usx2100 2 chan amp and a shiva but if i upgrade my system i wanted to go with a mono amp. was wondering if i could incorporate the old stuff with the new hehe. |
