Thread: Need help mmats 500.1 |
New member Username: Ford_73
Post Number: 1 Registered: 12-2003
| Posted on Wednesday, December 24, 2003 - 03:58 pm: |
i just got a mmats 500.1 does any body know how to brige it? |
New member Username: Motoman22
Post Number: 16 Registered: 12-2003
| Posted on Wednesday, December 24, 2003 - 04:23 pm: |
the 500.1 is a mono amp, one channel can't bridge ...or do you have the 500.2?
New member Username: Glasswolf
Post Number: 293 Registered: 12-2003
| Posted on Wednesday, December 24, 2003 - 04:43 pm: |
what are you trying to do exactly? are you trying to wire two subs to the amp? Mike's right. can't bridge a single channel amp, but it can handle more than one sub.
Post Number: 2 Registered: 12-2003
| Posted on Thursday, December 25, 2003 - 01:47 am: |
it says 500.1 butt it has 2 channels i want to drive my 2 mtx 6000 8's |
Post Number: 3 Registered: 12-2003
| Posted on Thursday, December 25, 2003 - 01:52 am: |
they say it's 500watts@1ohm |
Post Number: 312 Registered: 12-2003
| Posted on Thursday, December 25, 2003 - 03:27 am: |
Ok, that's not bridging. That's just parallel wiring. I figured that was what you meant. I'm used to seeing that mistake, so I catch it pretty quickly. Yes the two sets of terminals are there to allow easy parallel wiring of two subs to the amplifier. Just because it's a mono amp doesn't mean it can only power one sub. If you have two 4 Ohm subs, that'll be a two Ohm load on the amplifier. MMATS is a good company by the way. good subs and amps. Nice choice. Bridging is when you have a two-channel amp and make it into a mono amp, or a four channel amp into two channels. this is done by enabling a button or switch which inverts one of the two channels to allow the amp's full power to be delivered to a single channel instead of two channels. www.bcae1.com had lots of information explaining amplifier bridging, how to wire amplifiers and speakers, and so forth.
Post Number: 4 Registered: 12-2003
| Posted on Thursday, December 25, 2003 - 04:56 am: |
thank you |
